I want to connect Veristand and cRIO. First, I launched "System Explorer" and tried to set up "Custom Devices". Then, I chose "Scan Engine and EtherCAT" in "Custom Devices" and wanted to use "Auto-Detect Modules" to add my cRIO. But there was a error (as the pictue below).
I think the hardware connection is correct and I have installed all the drives in my cRIO. So where is the problem? And should I add my cRIO manully if the "Auto-Detect modules" was ok?
Could a master help me?
