Error -89137 When using a DI and DO on a 9375
Having an issue synchronizing the DI and DO on a 9375.  I need to run the output as a HWTSP and the DI can run as whatever, I may eventually need to run HWTSP on the DI but not yet.  I am trying  to avoid using the FPGA for now, but if it comes to that I will do it.  I tried messing with the ref clock source, but that is not available on that platform.  Also I it seems that this was an issue that NI knows about(and has in theory fixed) so I assume there is a solution.
(2,166 Views)
Did you check that resource was not being used anywhere else? This KB could be helpful
Error -89137 When Using Multiple NI-DAQmx Tasks or Terminal Routes
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kGabSAE&l=en-US
Also, you also try installing a newer version of DAQmx drivers
Chuan
(2,044 Views)
Accepted by topic author t.kendall
The solution to this ended up converting a couple seconds worth of errors to warnings which allowed the system to get past it's startup issues.
(1,966 Views)
