08-08-2019 05:51 PM
Having an issue synchronizing the DI and DO on a 9375. I need to run the output as a HWTSP and the DI can run as whatever, I may eventually need to run HWTSP on the DI but not yet. I am trying to avoid using the FPGA for now, but if it comes to that I will do it. I tried messing with the ref clock source, but that is not available on that platform. Also I it seems that this was an issue that NI knows about(and has in theory fixed) so I assume there is a solution.
09-13-2019 01:04 PM
Did you check that resource was not being used anywhere else? This KB could be helpful
Error -89137 When Using Multiple NI-DAQmx Tasks or Terminal Routes
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kGabSAE&l=en-US
Also, you also try installing a newer version of DAQmx drivers
Chuan
10-30-2019 09:45 AM
The solution to this ended up converting a couple seconds worth of errors to warnings which allowed the system to get past it's startup issues.
