08-13-2008 09:30 AM
Hi everyone,
I have a polling TCP and control application deployed to an FP-2010, and a counterpart application that communicates via TCP. The issue is that when I run the counterpart (fully built) on my development PC, it works, but when I run it on the PC that's going to be used as the tester, I get Error 59 when I try to open a connection (the second computer only has the runtime engine). I thought the runtime engine was supposed to be able to handle any built application, so I don't think I need the RT module on the tester computer, but I can't understand why I would get an error on one and not the other. I've tried power cycle, software rebooting through MAX, all those things.
Any ideas?
08-15-2008 11:14 AM
Hi Jeff,
Does the tester computer have two network cards installed? If not, is it on the same subnet as the development machine/FP-2010? Can you ping the FieldPoint from the tester?
08-15-2008 02:07 PM
08-18-2008 04:09 PM - edited 08-18-2008 04:09 PM
Hi Jeff,
Glad to hear that you managed to resolve the issue. I'm curious, though; what subnet are the dev computer and FieldPoint using?
08-19-2008 06:44 AM
