I have installed (through NI MAX) onto an sbRIO-9651 Linux RT System Image 21.5. When I try to get the system image using the built in example (Get and Set Real-Time System Image.vi in LV2021 with Windows 10 Pro) I get the following error:
I tried installing NI CompactRIO 19.0 for LabVIEW RT 2019 onto the sbRIO and the Get and Set Real-Time System Image.vi function works fine with that. Is there a new tool for imaging the latest installs that I need to use instead?
