Easy way to switch from NI 9146 to NI 9148 chassis
Is there a simple way to replace the one chassis with another using the same code? I recently upgraded from the NI 9146 to the NI 9148 chassis but I wrote out the entire code for my project using the NI 9146. So, simply put, is there a fast, easy way to replace this in the LabVIEW block diagram or will I need to rewrite the entire code?
(1,563 Views)
You can use the same project, just make sure you change the chassis and the ip address. You also have to make sure you have the relevant software packages installed.
(1,505 Views)
