05-07-2024 04:46 AM
It may sound strange, but I can't find an answer to this simple question. Does the cRIO-9054 (or 9053) come with a power supply?
I'm planning to order my first cRIO system (I've only used cDAQs before) but I can't find any information on this.
And if I need to order a power supply, which one is best for desktop use?
Thanks!
05-07-2024 07:45 AM
No, it does not ship with the power supply. From What You Need to Get Started
You can purchase PS-15 from NI or any off-the-shelf 9V to 30V power supply will do. Power connector will be included and you just need to connect the wiring.
05-07-2024 08:09 AM
Thank you very much!
05-07-2024 08:53 AM
For my last project, I used a TDK-Lambda DRB120-24-1. It is about 1/6 the price of NI's PS-15 with almost exact same specifications.
05-07-2024 09:07 AM
Thank you for the recommendation!
I'm not sure about the final layout of the whole thing (it could just be set up on the optical table after all with the desktop power supply), but if it ends up in some sort of cabinet, the mounted power supply is a way to go (i.e. both the cRIO and the power supply could be mounted on a panel or rail inside the cabinet).
Suggestions for compact, inexpensive cabinets are always welcome 🙂
05-08-2024 06:44 AM
I had both the power supply, the cRIO, another power supply, and an AC relay mounted on a DIN rail in my last rack.
As far as equipment racks, I am a fan of Emcore.
05-08-2024 07:10 AM
Thank you, will have a look (when they will repair their website 😁)
05-08-2024 07:19 AM
The page worked for me. It could be international issues.
