Hello Everyone:
Thank you for your continued interest in LabVIEW Real Time 8.0. I have a few answers for you as of now. R&D is in the process of updating the main document (Requirements for a Desktop PC as a LabVIEW Real-Time Target) and soon you will be able to refer to that document for all your answers.
Here are some answers
LabView 7.1 supports only paralell IDE/ATA hard drives.
Many new computers don't ship with IDE/ATA as an option.
Does LabView 8 RealTime support installing onto or booting from
SCSI drives? No. SCSI is not supported
SATA drives? Refer to the document where it talks about setting the BIOS to make a parallel ATA drive appear as a SATA drive.
USB drives? USB can be used for formatting purposes only. After formatting of hard drive is over, USB should be disabled.
Flash drive? Flash is not supported.
FireWire drives? 1394 is supported for formatting the drive.
Q. Newer Desktops typically don't have floppy drives anymore.
Does LabView 8 RealTime support its own istallation and booting into RealTime without a Floppy drive?
A. No. Installation and booting is not supported without a floppy. You will have to buy USB floppy drives if your computer does not already
have one.
Q. Does LabView 8 RealTime on a Desktop PC support National Instruments RS232,R2485 Serial boards?
Q. Version 7.1 supported Intel ethernet chipsets 82540, 82559, 82558, or 82550.
Are newer Intel Ethernet chipsets supported by LabView 8 Realtime on a Desktop PC?
A. Support has been added for the Broadcom 57xx chipsets which supports PCI Express devices. More information about this will be available in
the official document which will be updated soon.
Q. Does LabView 8 RealTime support multiple processors? What about Dual Core CPUs?
A. The underlying OS which is Phar Lap does not support dual core CPUs. Thus this feature is not available.
Q. Which version of Ardence's Phar Lap ETS does the new LabView 8 RealTime use?
Phar Lap ETS V12 has been out for some time.
Has National Instruments also moved to the newer version so that the newer capabilities of modern Desktop PCs can be used?
A. LabVIEW 8.0 RT uses Phar Lap ETS V12.
Again, these questions will be addressed in a more formal manner once the document is updated. R&D is working very hard to provide everyone with the most up to date and accurate information. I would highly recommend checking that document regularly.
I hope this helps.
Best Regards,
Jaideep
