I just instaled the PCI board together with the CA-1000 Connector Accessory Encloser. The test panel works, so I know that the device is installed. But when I connect a signal to the port on the CA-1000, I don't see the signal appearing on the test panel display. I just see a signal that is constant, with a little variation. By the way, I also have the PCI-GPIB card installed.
The problem there is most likely due to a bad connection somewhere. My suggestion to you is to cross check the connection you made with the Users Manual of the CA-1000 and DAQ board to confirm you done everything accordinly.
If that is not the case, the CA-1000 is probably damaged.
Regards Filipe A. Applications Engineer National Instruments
