Could not fine Rio-9104 vi after Real Time install
I received a vi from a contractor who told me I would need FPGA and Real-Time modules.  I installed evaluation versions of those, then tried to load the vi.  It could not find "nirviIntfOpen_cRio-9104.vi" and one or two similarly named files.  I assume these are files that would be included with the Real-Time install.  Why can't they be found?  When I check the NI directory, I find many files with names like nirvi*.vi, but not this one.
(2,857 Views)
C#,
You will also need to install NI-Rio, which is basically the driver cd.
It is a free download and is located here.
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(2,844 Views)
