07-11-2017 05:32 PM
Does anyone know if it is possible to connect to multiple myRIOs at once? I couldn't find any examples, but I may have been searching the wrong stuff. I will continue to research the topic, but any help would be appreciated.
Thanks!
07-11-2017 09:32 PM
More probable over WiFi assuming they were set to different addresses. I am not sure how the Ethernet Over USB will react. Hopefully, the system gives them two different IP addresses. Then it will be a simple connection to make. You will need to have the second myRIO added to your project.
