01-05-2012 07:45 AM
When I create a zip file the file I compress end up losing the last character in the extension.
e.g. creating a zip file "2012-01.zip" and choose to compress the file "2012-01.txt", it result in a file "2012-01.zip" containing a file called "2012-01.tx"....
Doing this on my computer it seems to work fine wothout this bug. Anyone with the password to the zip-files vi's that can tell me why this happen on my RT target?
I use LV2010 and my RT application run on a cRIO 9074.
01-05-2012 08:06 AM
It seems like the the last carachter just gets dropped since this workaround works.....
01-09-2012 05:19 AM
Hi
I was able to reproduce it and seems to be a bug in the LabVIEW 2010 that causes this, I tested it in LabVIEW 2011 and it seems to be fixed in in that version.
So the solution is to upgrade to 2011 or use the workaround you found
Regards
Espen
AE National Instruments
