Compile Worker 2016 and cRIO-9066 FPGA build fails
I have this issue with CRIO-9066 using the FPGA Compile worker 2016.
My LV is 16.0f5 (32-bit)
According to: http://www.ni.com/product-documentation/53056/en/
It (9066) should be supported since Vivado 2013.4, but as seen on screen dump I am using Vivado 2015.4.
I can build for other FPGA targets fine, but the CRIO-9066 model fails at synthesize.
Error from compile server attached.
Any inputs why this is?
(1,591 Views)
Hi Mauritius,
I tried compiling this myself with the software versions you mentioned and it compiled with no error at all on my end.
I would suspect an issue with the installation of the Vivado compilation tools may cause this, can I ask whether using the cloud compile is an option for you?
Mitch
(1,520 Views)
