05-09-2017 01:17 PM
Dear all,
I am new in compactRio fiels so maybe this is trivial for you.
I have a Labview application of CompactRio and NI 9375 input/output board.
I would like to define an event structure in a while loop.
The event should handle some task when one of the digital input of the NI9375 is true (+24V).
the problem is that the event does not work !
So nothing happens when there is a signal comming.
Thank you for your help !
Bests regards
05-09-2017 01:45 PM
You should post your code because I have to make some guesses as to what you are trying. Normally, I'm with you and I like to use events for everything but since it's an RT system, could you use polling instead? If you can, your life will be much simpler.
