02-27-2019 04:23 PM
As part of a project, we would like to communicate between LabVIEW installed on an NI myRIO-1900 embedded target and a mySQL database installed on a remote server. Is it possible and to what extent?
Although this is not very sensible given the limited resources of myRIO, we could also consider installing and activating a mySQL database server on the myRIO embedded map provided that it can be accessed from a (or more) remote mySQL client (s). Is it possible and to what extent?
I thank you for your feedback,
02-27-2019 11:26 PM
In myrio, Linux is running so, I guess general operation can be performed like this.
Connect to a MySQL database remotely
You can run shell commands on the device.
Running Shell Commands and Custom Applications in Linux Real-Time OS from LabVIEW
03-05-2019 01:39 PM
You could use TCP to connect to the mySQL database. Something like this?
03-05-2019 04:12 PM
Thanks for your proposition.
I will try soon and I will keep you informed of my tests.
03-05-2019 04:14 PM
Thank you very much "nanocyte" for this link.
I will read this with great attention.
