06-23-2017 11:20 PM
I have the Ni 9214 which I use to connect 10 thermocouples.
The Ni 9214 can collect data from up to 16 TCs but I need to collect data from up to 30 thermocouples
I thought about purchasing another Ni 9214 but I'm not sure that would work, any ideas?
Solved! Go to Solution.
06-24-2017 01:25 AM
06-24-2017 04:49 AM
The 9214 can handle 16 thermocouples. What chassis are you using? If you are using a single slot cDAQ chassis, you will want to get one of the 4 slot chassis as well. Then you can have up to 4*16 = 64 thermocouples in a single chassis with 4 of the 9214 in it.
06-25-2017 09:28 PM
I have a single slot cDAQ chassis.
thank you very much crossrulz, for your input, I should have realized that getting a 4 slot chassis would suffice
The single slot chassis that I have connects via USB and I use signal express to collect temperature data.
with the cDAQ 9174 I will have all the channels that I need.
