Chassis Temperature in NI cRIO-9072
I would like to make temperature drift compensation for accelerometer.
There are 2 possibilities:
1) Use thermocouple module
2) Use Chassis Temperature of build in into cRIO-9072 temperature sensor.
I do not need extreme precision so plus minus 1 degree is not an issue.
Is it OK to use Chassis Temperature for it and how to convert it into degree C(could not find conversion in module specific folder)?
(3,005 Views)
The only proplem with using the chassis temperature is that it is measuring the temperature of the chassis and the heating of the electronics will give you a pretty different reading from the actual surroundings.  If you want to try it out look here in the examples folder:
Message Edited by StevenA on 08-22-2008 08:02 AM
SteveA
CLD
FPGA/RT/PDA/TP/DSC
(3,001 Views)
