08-22-2008 04:36 AM
I would like to make temperature drift compensation for accelerometer.
There are 2 possibilities:
1) Use thermocouple module
2) Use Chassis Temperature of build in into cRIO-9072 temperature sensor.
I do not need extreme precision so plus minus 1 degree is not an issue.
Is it OK to use Chassis Temperature for it and how to convert it into degree C(could not find conversion in module specific folder)?
08-22-2008 09:01 AM - edited 08-22-2008 09:02 AM
The only proplem with using the chassis temperature is that it is measuring the temperature of the chassis and the heating of the electronics will give you a pretty different reading from the actual surroundings. If you want to try it out look here in the examples folder:
