Cannot add cRIO 9045 to LabVIEW NXG project
I have a cRIO 9045 hooked up to my computer and everything worked fine with LV2020. Now I decided to try LV NXG 5 - and struggle the get the cRIO running.
Setup
Everything is showing up in NI MAX and the cRIO is configured to run under LV NXG. All necessary software is installed on the target (I assume) and connection works just fine.
Problem description
After initializing a new project in LV NXG (5.0.0), I go to the SystemDesigner to add new hardware. The cRIO is showing up in the list so I click the 'add' button. This fails with something like "can't reach target under given address". No further error message etc.
Attempts to solve this
- change dynamic IP of target to static IP (same result)
- followed the steps described here  (didn't help)
- (!) re-installed LabVIEW NXG, NXG RT, NXG FPGA, CompactRIO drivers (in that order). This was really a pain but did not help either.
Related question
Can't add cRIO-9053 to NXG 5.0 project
-> the solution described there did not help me.
(1,791 Views)
Accepted by topic author FObersteiner
Solved it, finally!
What worked for me was to format the disk of the cRIO and re-install all Software, see How to Restore LabVIEW RT Target to Factory Default Configuration
(1,775 Views)
