Hai
I need to have 64 closed loop to control 64 temperature values, read using thermocouple's. Also i need to supply the option of if the closed loop should be P, PI, PD, or PID. Does any one have already built VI which does this?, or can anyone give me some suggestion on how to achive this?, I have used the Simple PID VI, supplied along with LV RT and have modified it as per my needs, i mean i have added an extra input to the PID through which i can specify the "control type", array of "setpoints" and "process variable, this PID gives an "array of output". This VI seems similar to the one supplied along with LV, but internally is quite different . I would be willing to supply this VI to any one if they will look in to it and would certify that the modification is valid and will not cause any errorneous output.
Regards
Arun
