11-16-2011 09:25 AM
I was using the Ni 9213 along with NI USB 9162 to record data from thermocouples. Before beginning with my measurements i used the LabView Signal Express Calibration tool to ensure my thermocouples are calibrated to get the best results. I wanted to enquire if the calibration is performed for the channel on the NI 9213 or is it specific to one thermocouple.
Say I have calibrated a particular thermocouple and saved the project. In another project if i use the same channel for measurements with the same thermocouple do i need to perform a calibration again or does the previous calibration data hold good for that particular channel.
Roshan
11-17-2011 06:15 AM
Hi Roshan,
I think it is not recommended to use the same configuration for different modules. Because you should enter the serial number for each sensor and you get the values exactly from your device. So not each device reacts 100% the same as the other, so I would recommend to calibrate each device separately.
Michael
11-17-2011 10:06 AM
Hi Micheal,
Thanks for your reply. I think i understood what what you had to say. What i wanted to know in particular is the calibration wizard in LabView SIgnal Express, does the calibration differential values get saved in the hardware or is it saved only for the particular project in which the calibration is performed. Because everytime you open a new project, one has to select which thermocouples are connected in which channel and calibration must be performed again. So i guess its Project file specific. Hope you can clear this question i have.
Roshan
11-18-2011 02:23 AM
Hi Roshan,
I just talked with a colleague and we both think it is project specific because there is nothing saved to the hardware.
Michael
NIG
11-18-2011 03:21 AM
Hi Micheal,
Thanks for your reply. Even I think that the settings for the calibration are project specific. So this would imply when i change the project, i could also change the thermocoulpes and use another calibration settings for them.
So by this, i could change thermocouples and use the same NI USB device in different projects with different calibration settings.
Hope you could sign off on this.
Roshan
11-18-2011 04:52 AM
Hi Roshan,
yes I would agree to that. Because the settings are "saved" on the software you can use the 6221 device with different calibration settings in different projects.
Michael
NIG
11-18-2011 04:56 AM
Hi Micheal,
Thanks for your reply. I didn't understand 6221 device??
Roshan
11-18-2011 04:57 AM
Sorry, your USB-device;-)
