CRIO FPGA target simulation and direct connexion
I'm working on developping a program using a CRIO-9075. With LabVIEW 2020 I followed instructions to install Real time, FPGA module and the Ni-CompactRIO driver (all latest version found in the package manager). When I try to configure the chassis in MAX it appears that it is connected via Ethernet but cannot be configured due to driver issue. I then tried to simulate it in LabVIEW with the FPGA target, but I can't find it in the list: all I can see is cRIO from 9030 to 9068... Anyone knows if it's some kind of compatibility issue or for other reason?
Thanks in advance
Message 1 of 1
(1,431 Views)
