07-10-2012 07:15 PM
07-11-2012 04:23 PM
Hi allch,
The BREAK is a message that comes from the lvalarms (timed loops) portion of the code. This message is reported when the timed loops hit a serious issue. Try switching your timed loops to regular while loops in your application and let us know if that fixes the issue.
08-24-2012 07:14 AM
I had the same problem once. Following the advice from Aldo A will solve the problem. The most secure option is to replace ALL timed loops from your application. If this is not possible than there should be not more than one timed loop. If you use more than 1 timed loop the BREAK will potentially occur and lead to unpredictable behavior of your application. My application was still running after a BREAK, mostly.
12-14-2012 06:52 PM
Thanks guys for your help, this solved this issue, along with some code improvements to reduce CPU load.
