03-31-2014 09:44 AM
I have been using a local remote server to compile my FPGA code. After receiving the NI Developer Suite update DVD's I proceeded to install the new updates to the system(see attached File). After a successful upgrade I rebooted the server. When I try to run the “FPGA Compile Worker” nothing happens.
How can I get the FPGA Compile Worker to start?
Gus
03-31-2014 03:47 PM
Upgraded .NET 4.0 to 4.5 and the problem went away.
04-03-2014 12:00 AM
had also the same problem and solution, thanks for sharing 😉
05-06-2014 01:42 AM
I also had the same problem - solved by installing .NET Framework 4.5. In the meantime NI released a patch that should fix this issue:
http://digital.ni.com/express.nsf/bycode/xilinx144f1en
