06-05-2018 09:59 AM
I'm working on getting spectrum data from R&S spectrum analyzer CMU 200.Well I'm totally new in this domain cauz actually i just want to acquire signal from the spetrum and save it as csv file for example to work on optimization with genetic algorithm.I have RSCommander program on pc I get connected with the spectrum through GPIB connection but the problem here is that 'trace' in disabled as well as 'hardcopy' I tried something else I donwlaoded the prgram FSxRecordPlay but I get the error 'check for connection and make sure you have the right instrument descriptor'.I'm blocked since a month because every day I try something new and dosen't work with me I'm so confused.
Please is there any solution or another method I can follow.
Thank you.
Solved! Go to Solution.
06-08-2018 04:48 AM
Hello zaynebzayneb,
Can you tell me more about the National Instruments's product you are using?
Thank you and have a good day!
Corentin
06-11-2018 02:09 AM
Hello I'm using National Instrument GPIB_USB adaaptor to get connection pc/spectrum analyzer
06-11-2018 03:57 AM
Hi zaynebzayneb, RSCommander does not support CMU200 as a spectrum analyzer - therefore reading the trace does not work.
06-11-2018 04:07 AM
ok thank you you confirm my doubt. So is there any solution or other method you can propose for me?
06-11-2018 04:13 AM
Which programming environment are you skilled in?
06-11-2018 04:20 AM
Well eclipse IDE.Or I'm thinking of matlab but concerning matlab I don't know several functions but if there is a practical solution I'm ready to work on it .
06-11-2018 04:38 AM
Matlab is a good tool for such tasks, I wrote an Application Note 1MA171 on the topic of remote-controling instruments from Matlab: http://www.rohde-schwarz.com/appnote/1MA171
But you need to get familiar with the SCPI commands language - I suggest a small tutorial here:
https://www.rohde-schwarz.com/driver-pages/remote-control/drivers-remote-control_110753.html
Go through the 1MA171 Chapter 2: Direct SCPI Commands Communication and try the MATLAB_directSCPI_Hello_World.m example. Let me know if you've managed to connect to your instrument.
Cheers
06-11-2018 04:50 AM
okk I will read the tutorial and try to run the example. I will inform you if I managed to connect it or not.
thank you
06-11-2018 07:32 AM
Hello I tried Hello world example but it doese not work cauz it is GPIB connection and not TCPIP so I tried the Instrument control toolbox and it work with me but the problem here is that I try to customize the code to work with me but for example the property '.Write' is not an accessible property for VISA_GPIB. What I can do in this case
