Accessing Fieldpoint from CompactRIO
I'd like to read/write Fieldpoint channels on the network from a CompactRIO RT controller.
But i'm not able to deploy any VI containing "FP Read" or "FP Write" blocks. An error like this occurs during deploy:
Deploying FP Read (Float Array -IO).vi
Failed to download FP Read (Float Array -IO).vi
LabVIEW:  Failed to load shared library FPLVMgr.dll:ialv_service_read_callback_fast:C on RT target device.
LabVIEW:  Failed to load shared library FPLVMgr.dll:ialv_read_fast:C on RT target device.
LabVIEW:  Failed to load shared library FPLVMgr.dll:ialv_getTagElements:C on RT target device.
I also tried to manually copy FPLVMgr.dll on the device before deploying, but didn't help
(3,194 Views)
You won't be able to access the Fieldpoint I/O from a cRIO controller using the Fieldpoint API. You will need to use shared variables to communicate between the two.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,188 Views)
Hi SnamProgetti,
for communicatio between cRIO (i.e. RT target) and FP/cFP, try to use Logos protocol trough DataSocket API. Here's a document:
What Are the Different Communication Techniques Using Logos and FieldPoint?
FieldPoint VIs are not supported under RT targets, so you better use Datasocket or, if possible, Modbus I/O server (for 180x Fieldpoints) or shared variables (for cFP RT targets).
Hope this helps,
Fabio
Fabio M.
NI
Principal Engineer
(3,167 Views)
