02-09-2009 09:14 AM
Is to possible to access a shared folder on the local network from a RT machine (Fieldpoint for example)?
On Windows i use \\PCname\Foldername as a path and it works, but on RT i get error 1430 (path is empty or relative)
02-11-2009 02:44 AM
Ciao Snamprogetti,
the way you're using to share files over the network in Windows is OS specific and cannot be used "as is" in Pharlap ETS (the OS Field Point is using). At this time, we cannot make use of a networked drive from LVRT Pharlap OS.
Searching a bit on the web, I've found this 3rd party tool that may help:
CIFS/SMB File Sharing for VxWorks or other RTOS
Anyway, I suggest you to use the standard ways LabVIEW sugggests (TCP/IP, FTP trough Datasocket, etc.) in order to transfer data or files over the network.
Hope this helps,
Fabio
