About PCI-8531canopen error - 2147136764 occurred in CANopen NMT write.vi: 1840006
Highlighted
In the process of using Ni pci-8531, I received the CANopen error - 2147136764 occurred in CANopen NMT write.vi: 1840006 after the launch of the LavVIEW program. I don't know what caused the failure, what is the meaning of this string of numbers 1840006? After the fault pops up, click continue, and the program can continue to run.
(572 Views)
Highlighted
Was this issue resolved? I have seen the same error occur with a PCI-8531 with different text. The suggested action is a manual reset of the system.
My code opens an node etc with no issue / errors but flags this error on the first instance of an SDO read / write. Any thoughts? Could this be a hardware error?
Error code: -2147136764
Error text: CANopen SDO Read [Block].vi:130003
Thank you, Delta J
(197 Views)
