11-05-2019 03:43 PM
I am trying to use the example "NI 9220 User-Controlled IO Sampling.lvproj" originally made for cRIO-9101 with cRIO-9064 under NI LabVIEW 2014 SP1 (32-bit). The NI 9220 "User-Controlled IO Sampling (FPGA).vi" declares the errors: “Read I/O Method: XNode is not executable” & “Read Status Method: XNode is not executable” with Details: “This node is not executable because an unexpected error occured during code generation.” The LabVIEW Help offers, among others, two solutions: "Remove the XNode from the block diagram" & "Re-add the node to the block diagram." Please help: How can I remove or re-add the XNode or what else could I do?
11-13-2019 05:10 AM
To solve this, the broken Read I/O Method and Get I/O Read Status Method nodes should be deleted from the block diagram and replaced with new ones from the Functions palette,
Kind regards,
Vilius
11-13-2019 06:06 AM
Great. Functions perfect. Thank you, Vilius!
