05-18-2018 04:10 AM
Hi!
Can anyone suggest a NI device/module that has 16-bit ADC and at least -5 to +5 V range?
Solved! Go to Solution.
05-18-2018 05:28 AM
How do you want to connect to such a device? cRIO? Ethernet? USB? PXI? PCI?
05-18-2018 05:43 AM
cRIO or Ethernet or USB.
05-18-2018 06:06 AM
Then you might want to look at the NI-9205.
05-18-2018 06:13 AM
Thank you, this looks good. Something from 92xx series will definitely be suitable.
http://www.ni.com/en-gb/shop/select/c-series-voltage-input-module?modelId=122157
