Random Ramblings on LabVIEW Design
Community Browser
Labels
Re: I'm not being critical but... (Re-use) Part 4
swatts
As I'm preparing for my presentation at ALVIN tomorrow it occurred to me that there was one aspect of this discussion about Environment VIs vs Project VIs that could be improved quite easily.
So just to clarify.
Most if not all of the VIs in these directories can be edited or replaced. This will potentially cause changes across all of your projects on this machine and undo these changes when you load your project on a new machine. This somewhat makes a mockery of source code control.
I think it would be good to have some warning of this. Something akin to the following dialog box would work.
Personally I would go further and move the affected VI into the project directory, but this at least explains the ramifications rather than silently causing chaos in your code-base.
I think we're getting close to having this idea thrashed out now.
Here's where I'm staying for the week (I'm a lucky lad really)
Lots of Love
Steve
Steve
Opportunity to learn from experienced developers / entrepeneurs (Fab,Joerg and Brian amongst them):
DSH Pragmatic Software Development Workshop
Random Ramblings Index
My Profile
Comments
crossrulz
Knight of NI
Here are a couple of ideas in the Idea Exchange you might want to consider:
"Save All" needs a soft barrier to prevent accidental use
Make the VI's from the "vi.lib" Read-only
GCentral
swatts
Cheers Tim
I'd go further and attach the same rules to instr.lib and user.lib too.
Also I really should check the Idea Exchange out more often.
Steve
My Profile
Taggart
When I create vipm packages, I always add a post install vi which makes them all read only.  I don't want anybody changing them.  If they need to change, then you have to go back to the source, change it and rebuild.  It seems to work.
Seems to me you could write a simple vi or script to find everything in vi.lib and make it read only.
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
joerg.hampel
Sam, I do a similar thing for source distributions and add a random password.
DQMH® (The Future of Team-Based LabVIEW Development)
Intaris
Proven Zealot
I'm actually not sure whether my following post should be taken seriously at all....
Why aren't these things extendable as opposed to editable? Make all the code in these directories members of read-only classes which can only be modified by overriding them and explicitly using the child versions in code.  That way, you'll at least have to put the child somewhere (in your project) and it's clear in your code that you're using a different version.
IDE problems ahoy!
