10-19-2017 05:43 PM
Hello all,
I have a project that I've written in LabVIEW 2017, and it runs fine on my development machine. When I try to build it into an executable, the rtilvdds.dll gets pulled into the 'Data' folder, but when I actually run the executable, I get the following error:
It gives me this error for any VIs that use any components of the toolkit. Do we know if the DLL is compatible with LabVIEW 2017, or if there is any issue when building it into an executable?
Thanks for the help!
10-19-2017 06:39 PM
Hey aprillest,
I'm not sure if this applies to the toolkit but it is possible that we have to configure our system similar to how it describes it in this document below.
Set Up the Environment on Your Deployment Machine - https://cdn2.hubspot.net/hubfs/1754418/RTI_Oct2016/PDF/RTI_CoreLibrariesAndUtilities_GettingStarted....
10-20-2017 02:55 AM
Hi aprillest,
In the "Common questions" topic we have a section which explains how to fix this issue:
I hope this helps!
Angel.
10-20-2017 08:52 AM
This is what I ended up doing.
Thanks for the link!
