RF Multi Channel
NI RF Phase-Coherent Multi-Channel 1.2.2
Introduction
Reference software for performing phase-coherent multi-channel signal generation and acquisition with NI RF products.
Phase-coherent multi-channel in this case means each channel shares a single LO source and are all tuned to the same RF frequency.
Version 1.2.2 fixes an issue in the Acquisition software that could cause low memory option analyzers to experience a buffer overflow during stream-to-disk operation.
Supported Hardware
     Acquisition
  • PXIe-5663
  • PXIe-5663E
  • PXIe-5665 (3.6 GHz)
  • PXIe-5665 (14 GHz)
     Generation
  • PXIe-5673
  • PXIe-5673E
Dependencies
     Acquisition
  • NI LabVIEW 2010 or later
  • NI-RFSA
  • NI-RFSG
  • NI-Sync
  • NI Modulation Toolkit
  • NI Spectral Measurements Toolkit
     Generation
  • NI-RFSG
  • NI-Sync
Changes from 1.2.1
  • Fixes an issue in the Acquisition software that could cause low memory option analyzers to experience a buffer overflow during stream-to-disk operation.
Changes from 1.2
  • Fixes a bug in the Generation software that caused single generation (i.e. non-looped) playback to generate part of the file twice, and output signal for a period of time longer than that represented by the data in the recorded file.
Changes from 1.1
  • Skip NI-TClk configuration for single-channel use cases. This is not a fix for anything, rather a clarification that you don't need Ni-TClk for single channel usage.
  • As a followon to the previous bullet, now use NI-RFSA/NI-RFSG Initiate for single-channel usage instead NI-TClk Initiate
  • Improved interface for In-Band Retuning functionality. The user specifies a upconverter/downconverter Center Frequency for all channels (since they share an LO) and also specifies a digital OSP shift for each individual channel if so desired. The actual center frequency will be the sum of the upconverter/downconverter center frequency and the individual channel's OSP shift.
  • Tweaked the user interface / front panel, mainly reducing the size to accomodate lower resolution displays more conveniently.
(10,789 Views)
Thanks a lot for the great example!
(4,696 Views)
是否支持5644?
(1,790 Views)
