RF Measurement Devices
how to demodulate FSK signal using pxi-4461
hai,
 how can I demodulate an FSk signal obtian form DUT using PXI-4461? Is there any explample program for demodulating FSK signal using pxi-4461 or anyother toolkit using pxi-4461?
 I am using Labview 7.1
Regards
Assumptha
(6,924 Views)
Hi Assumptha,
You can use Modulation Toolkit to perform this demodulation. There is not a FSK example using DAQmx but there is one for FM demodulation to guide you to the process. To perform a FSK demodulation, you can use the shipped example "MT FSK Mod-Demod.vi" located under LabVIEW x.x\examples\Modulation\simulation examples\Programming
Good luck,
Gerardo O.
RF SW Engineering R&D
(6,900 Views)
