RF Measurement Devices
calibration of VNA N9925A
 Hello
    I have a VNA N9925A I want calibrate this VNA with Labview 2018 .how i can do that ?
(3,813 Views)
Since it is a non-NI product, the best place to ask this question is to Keysight support or on Keysight forums.
Santhosh
Soliton Technologies
(3,781 Views)
Tahar7,
What are you really asking for?
Typically you calibrate a VNA frequently using either a manual cal kit or an e-calibrator.
You may be asking if you can use LabVIEW to automate the above calibration of your VNA N9925A.
This assumes you already know how to calibrate the VNA manually or through the UI of the VNA, and you have a cal kit or e-calibrator.
In that case, it comes down to whether this is a LV instrument driver and it if has the necessary API functions.
A quick search shows the LV driver:
Keysight Technologies / Agilent Technologies N9925A FieldFox Handheld RF vector ne - Instrument Driv...
You'd have to install and check out the driver and shipping examples to see if one is provided for VNA cal.
An E-calibrator is going to be the easiest approach, saving the complexity and risk of manually swapping out cal references. The trade-off is that E-calibrator is more expensive, and must come from Keysight.
If you use a manual cal kit, you will need to decide which is best for your case and write a routine if it isn't already written (e.g.  Short-Open-Load-Thru  (SOLT) or Short-Open-Load-Reciprocal (SOLR)).  You can use almost any decent cal kit rated for your frequency.  Keysight should have fields where you enter the expected  value of each cal reference that you must then measure with the VNA to perform the cal.
Hope this helps.
Kitt
(3,769 Views)
Santos-13
   Thanks for your advice
(3,763 Views)
KittF,
   I use  a manual cal kit, Short-Open-Load-Thru  (SOLT). I have labview 2018 and I intalled the driver for labview of the
VNA N9925A  and I see all the exmples in this driver  but there is no exemple for calibration.
    I want make this calibration manual by using the front panel of labview and not by using the push bouton of the VNA.
thankes for your help.
(3,762 Views)
