12-05-2018 01:25 PM
Hello All,
In my application, I need to generate ASK modulated waveform at 3.6G with <300us ON time & 10% duty cycle. Is it possible to generate such waveform with NI PXIe- 5644R VST?
Please suggest if any alternative method, or need to install any drivers.
Thanks in advance,
Swamy.
05-07-2019 12:49 AM
Hi Swamy!
You can select the OOK modulation type using the PXI/PXIe-5650/5651/5652. But you are using PXIe-5644R so, you cannot select this property.
Please refer to below link.
http://zone.ni.com/reference/en-XX/help/371025V-01/rfsg/modulation_modes/#OOK
So, you should code generate ASK modulated waveform. I think these links are useful.
http://www.ni.com/example/30106/en/
http://www.ni.com/example/30149/en/
Before you run these examples, download NI Modulation Toolkit in NI site.
Sebari.
