12-04-2007 03:54 AM
12-05-2007 03:13 PM
Hello Dannn,
The 5661, which is a combination of the 5600 and 5142 will use the NI-RFSA driver. If the 5600 is used alone, then it will use the NI-Turner driver. The 5142 will use the NI-SCOPE driver if it is used alone. If you want to use them together, then you have to go into MAX and associate the 5600 with the 5142.
The PXIe-5122 (which uses the NI-SCOPE driver) cannot be associated with the 5600 so that the NI-RFSA driver can be used. However, they can be used in the same application. You are just loosing the tight synchronization that you get with the NI-RFSA driver.
The 5600 has a fixed BW of 20MHz and cannot be adjusted. The NI-RFSA driver can span the 50MHz+the BW with no problems. The only way that the 5600 can provide real-time continuous data is if the BW is set to 20MHz.
The RF Switches are only required if you need more than one signal to be connected to your 5661. The 5421 is not needed to stream data to a RAID Array. However if you want to replay and stream the data from your RAID Array, then I would recommend the 5672, which uses the NI-RFSG driver.
12-09-2007 09:36 PM
Hi
Thanx for the reply. now i want to ask another thing. can i use 5661 alongwith controller such as 8106,8130 and modulation toolkit for real-time demod of qpsk/qam?
danyal
12-12-2007 11:00 AM
03-12-2008 11:30 PM
03-14-2008 10:53 AM - edited 03-14-2008 10:55 AM
03-14-2008 10:31 PM
03-18-2008 10:01 AM
03-19-2008 01:22 AM
The point about determinism is clear. Thanx for the insight, now comes the problem of NI-RFSA driver that is not currently offered for RT, that means what? (pl refer reply 3 to my post by Matt) how to go about it if i choose RT? the reason i am not considering FPGA at the moment is because i need a flexible solution, easily upgradabale etc.
danyal
03-19-2008 10:21 AM
