09-02-2011 10:49 AM
Hi
I am running into a problem. It has been a week but couldn't figure it out. I have PXI 5620 Digitizer and Labview 2010 SP1. The error only occurs when I run EXE, not in debug.
Here is the error:
LabVIEW: Open VI Reference no longer matches VIs in memory by filename. A filename is no longer sufficient because the full name of a VI now includes any owning libraries.
VI Path: C:\SWA-1302-003 2.4GZ FT\2.4GZ Final Test Application\2.4GZ Final Test.exe\1abvi3w\vi.lib\addons\Modulation\niScope\mod_Set Receiver(RFSA).vi
09-06-2011 05:44 PM
Have you taken a look at this KB?
I can't see your whole VI (or potential sub VI's), so it might be helpful to post that. It seems like you are passing a VI reference name at somepoint, and when this is compiled into an executable, it is no longer looking in the correct location.
Are you building an installer or an executable?
Jon S
12-08-2011 12:47 PM
I see "1abvi3w" as the folder name in the path where the real LabVIEW folder name should be!? Why is that strange-looking name used? We're having the same problem trying to execute our built app that uses a Report VI.
12-09-2011 04:44 PM
Hello, can you post the related screen shot of where you are referencing the VI.
Are you using the Open VI Reference function or are you getting a VI reference another way?
