12-02-2018 01:34 PM
As the title states, i need to find out how to generate custom bitfiles for the aforementioned VST using LabVIEW 2018. It can be done on LabVIEW 2012 as I am currently using. However, LabVIEW available on a different, better PC where i want to generate the files is 2018. Therefore, i would like some guidance in this regard.
12-02-2018 02:06 PM
If i can program the DIO ports of the FPGA without having to generate customized bitfiles, that would work as well.
12-03-2018 03:39 PM
You can't program the DIO ports of the VST without generating a custom bitfile.
There are two options for programming the FPGA on the VST, the instrument design libraries and FPGA extensions.
http://www.ni.com/tutorial/14180/en/
The latest version of the IDLs supports up to LV15.
http://download.ni.com/support/softlib//RF/NI%20VST/15.0.2/readme.html
