I am trying to measure Power Supply rejection for a diffrential amplifier using a PNA-X (Agilent 5245a). The problem I am running in to is determing the peak-to-peak voltage level off the PNA. My understand, and given I am relatively new to using this PNA, is that it only displays in power level (dBm) and not voltage. I can set up traces to convert power level to RMS voltage to peak voltage to peak-to-peak voltage however this is not an exact science especially when dealing with frequencies > 10GHz due to noise, cal issues, etc.
I guess my question to the masses is, does anyone know of a good way of measuring PSR/PSRR from the PNA?
Thanks in advance.
