10-16-2017 01:08 AM
Hi everyone!
I have two RFs and I want to combine then to make 1RF. Can Anyone guide should I connect them to CH01 AND CH1A and take outpur from COMA or is there any other channels which I have to connect. Kindly provide help in this, It would be really appreciateable
10-17-2017 11:58 AM
@Zarrar,
Could you elaborate on what exactly we are trying to achieve here? Also I would recommend opening up the NI-SWITCH Soft Front Panel and exploring the different routing options that are available for this device.
03-16-2018 09:21 AM
Based on the other user's post with the switch topology diagram, your two RF signals would go into COM A and COM B respectively and the COM A and COM B ports should be commanded to connect to the SUMAB paths. This will provide a combined RF signal at the SUMAB port that is made up of the signals connected to COM A and COM B.
