12-19-2005 04:19 AM
12-21-2005 02:02 AM
12-21-2005 07:39 AM
Hello Phillip
Thanks for your reply,
My problem is solved now , actually I had to use the Microsoft's drivers which I was not doing before (as I was using the drivers which came with the Bluetooth dongle).
With Regards,
Sandeep.
04-01-2006 04:33 AM
Hi,Alanka!
I face the same problem as you!My BT dongle is using the IVT BlueSoleil driver as well. I cant install the Microsoft BT driver.Here is my question:
i)Does I ned to change the dongle?
ii) How to find the GUID of the dongle?
Thanks!
04-01-2006 07:23 AM
Hello Kuah
My problem is solved now actually when we deal with LabVIEW we have to use only Microsoft's drivers so we need not to install IVT Bluesolil drivers.
Secondly you must have Windows XP SP2 , then insert your dongle into USB port and wait for a few seconds a Bluetooth Icon will appear in the systems tray , it means machine has detected your dongle and there is no problem with it , and ready to use with LabVIEW.
So, Check for it and I dont think so you have to change the dongle....also you can find the Bluetooth device from Control Panel of your computer.
Regards
Alankar
04-01-2006 11:52 AM
Thanks Alanka.
My dongle is come along with the IVT software. I have install Win XP SP2 to my computer,but it seem like cant install my dongle with Microsoft BT driver, and there is no BT icon in the control panel as well.
Do u mind to tell me, which model of dongle do u using now? My project is going to transfer ECG signal through BT module to the dongle in computer. But, the message 'Error 58 occured at BT Open Connection' is pop-out when i m gonna run my application. What is happening actually?
Finally, how to find the GUID for the dongle as the ni person tat I contact say the problem may probaly cause by GUID.
Thanks.
04-02-2006 04:36 AM
04-02-2006 07:46 AM
04-02-2006 01:16 PM
04-02-2006 01:49 PM
Alanka,
Yea,I know,the Ms Driver is come along with the SP2. My dongle work well with the software which come along,IVT BlueSoleil. But,when I have test out with the examples of BT in the LabVIEW, the error is pop out. Thats why I m wondering the following problem may occure:
i)GUID code- I have no idea how the code is generated, or all the GUID code is same?
ii) my dongle is not compatible with the Ms BT Driver. I wana know wats the brand of the dongle tat you were used lastime, to enable me purchase the compatible dongle.
Thanks.
