RF Developer's Network
Reply
NIWeek Demo: Using NI FlexRIO to Get 80 MHz of VSA Instantaneous Bandwidth
This demo shows an NI 5762 adapter module for NI FlexRIO working with the new NI PXIe-5603 downconverter to create a vector signal analyzer (VSA) with 80 MHz of instantaneous bandwidth. It also shows demodulation and measurements on an IEEE 802.11ac signal – which has a bandwidth of 80 MHz.
Watch the video:
Visit ni.com/rf to learn more.
(4,684 Views)
Re: NIWeek Demo: Using NI FlexRIO to Get 80 MHz of VSA Instantaneous Bandwidth
Over here you have replaced NI 5622 with the FlexRIO module and 5762 adapter.
Considering that
1. The Sampling rate for both 5761 abd 5762 is the same.
2. 5622 is used in both 5665 and 5663
Can i use NI 5761 as a replacement of 5622 digitizer in NI 5663 VSA and get 80Mhz of bandwidth?
(1,223 Views)
Highlighted
Also, will 750MBps throughput RAID be sufficient for streaming 80MHz of bandwidth?
(1,223 Views)
Reply
