Quick Drop Enthusiasts
The Splitter (& Pane!) Manager
During development, or right before distributing a release, applying splitters and pane settings is always a tedious task. Sometimes you don't even see where the splitters are, if they have the same color as their adjoining panes.
So, I wrote this Splitter Manager QD. It basically spawns a semi-transparent window that allows you to find panes/splitters, and get/set the most used parameters.
Can be found here:
https://github.com/Sylphe88/UI-Box/releases/tag/SM_1.0
I also wrote an article about it if you want to know more:
https://thelvlab.wixsite.com/thelabviewlab/single-post/2018/08/16/The-Splitters-Sentinel
--Eric
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
Message 1 of 14
(3,245 Views)
Nice! Just this week I have been been developing a UI with subpanels and cursing a bit about it. I will have to try this out.
Message 2 of 14
(3,231 Views)
Another option is using UIM https://forums.ni.com/t5/UI-Interest-Group-Documents/User-Interface-Manager/ta-p/3539490 with SubPanels. I think it might be more flexible.
Piotr Kruczkowski
Certified TestStand Architect
Message 3 of 14
(3,221 Views)
I think you might have misunderstood what this does.  This is not a UI manager to be used during deployment, this is tool to make the IDE better by adding additional tools.  There isn't anything this tool does that LabVIEW on its own can't do.  This just makes developing UIs that use lots of splitters and panes, easier to develop for.
Message 4 of 14
(3,167 Views)
So I like this idea and decided to mix it up a bit.  I already have lots of QuickDrop shortcuts and this feature to me really seems more appropriate for a Tools Manu item.  So attached is a zip.  Extract to:
<LabVIEW Install>\Projects
Then restart LabVIEW and now in your Tools menu there should be a Splitter Manager.  Run this and you'll have a new model and semi transparent window just like before.  Except now if you are looking at a block diagram of any VI it will be hidden.  If you look at the front panel of a VI it will be populated with that VIs information.  I put in some work arounds for things that shouldn't ever happen, but now if you try launching it multiple times from the Tools menu, only one window will ever be running, and closing it closes the one instance.  This works off of the VI Activation event to get the new reference to the VI the user selected.
I also was surprised that a tool for managing splitters and panes, didn't have any splitters.  So I changed the UI to resize better.  Now if you change the height the number of rows will increase.  The window can also be wider but all it does is center the buttons up top and not the row of clusters below.
EDIT:  Oh this might also be good for a right click item, so if you right click on any splitter this dialog comes up.
Message 5 of 14
(3,060 Views)
Good thing you enhanced it! I actually hesitated to implement in Tools but meh, I dislike navigating menus and prefer shortcuts (purely personal tough).
Updating the controls through VI Activation was on my to-do list, as the primary work was a 1-evening shot, but it turns out I was right to go on vacation, you did it in my stead 🙂
As per other UI stuffs, it's also valuable! If you don't mind I'll add your edits to my repo later.
Thanks anyway Hooovahh
Message 6 of 14
(2,972 Views)
Go ahead and use what I did.  Ideally I'd say this can also be a right click plugin where you right click a splitter and can open the window as well...or at least that's what I would have suggested had I not talked to Darren at the CLA Summit where he informed me that you can't have a custom popup menu for right clicking a splitter.  He said Stephen had a good reason for this limitation but couldn't remember it at the time.  I think QD is overused at times for functions and so I try to avoid using it unless it does make sense.  In my opinion this just works better as a tools (or right click if it were supported) and is less ideal as QD but whatever.
Message 7 of 14
(2,963 Views)
I saw a small issue when searching for the newly activated VI. You search for a ":" probably to account for clone VIs but this strips off all the VIs that have a namespace so I changed the how it filters with a MatchPattern.
I added your tool to my UI-Box repo!
As per a right-click that would have been the best compromise indeed, too bad we can't customize it 😧
--Eric
Message 8 of 14
(2,937 Views)
--Eric
What about adding it to the right-click menu of the pane, is this supported?
I'm Organizing the GLA Summit!
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
Message 9 of 14
(2,935 Views)
@FabiolaDelaCueva wrote:
--Eric
Damn Fab you're already trying to make my QD name sound confusing. A splitter manager that pops up on a pane right-click... *sigh* anyway pane right-click popups work so that's doable. I just don't find it convenient because pane right-clicks are only viable on a pane scrollbar but these guys are not often visible even at edit time.
So many plugin possibilities... *_*
Edit: WOW actually pane popups are also active when right-clicking a splitter. This is even more confusing but oh well... However from what Hooovah's and Darren's, that shouldn't be expected behavior should it?
Message 10 of 14
(2,913 Views)
