05-21-2012 03:45 PM
The template for creating a Quick Drop Keyboard Shortcut plugin VI is here:
LabVIEW 20xx\resource\dialog\QuickDrop\QuickDrop Plugin Template.vi
Should I make this VI a template (.vit) instead? I have the path to this VI hard-coded in a few places in Quick Drop that I would need to change. Other than that, would making this VI a .vit instead of a .vi adversely affect any of you?
05-21-2012 04:40 PM
Nope, I think it would make a lot more sense as a template since it is exactly that, and you'd be less likely to accidentally overwrite the original. I'd even say it should be added to the File > New... dialog, but that's probably a more complex change than just renaming it to .vit.
