Quick Drop Enthusiasts
Running out of keyboard shortcuts
Oh, and I wouldn't worry about the performance of the list - I know that the algorithm can easily handle tens of thousands of elements quickly, so adding a few dozen plugins shouldn't be a problem. The only problem would be with the panel, but like I said, just keep it closed if you want QD to respond faster. It can also work asynchronously, but I think if you want a quick response most of the time, it should just be closed.
___________________
Try to take over the world!
Message 31 of 34
(2,405 Views)
You all might be interested in "Mouse Gestures" available at JustGestures.com
In the grand scheme of other ways to invoke a command, this has proven particularly useful above and beyond the QDSK and even moreso into my OS environment.
Long story short, it watches for "RightClick+Drag" shapes or strokes and performs things like running VI or simulating keystrokes based upon the detection which is particularly powerful in this realm.
~Norm
Message 32 of 34
(2,405 Views)
Is there any solution for this over last 7 years?  Recently I'm facing with such overlapping of same shortcuts issue.
Ajay MV
Message 33 of 34
(2,292 Views)
Check out Quick Run. It lets you assign multiple letter combinations to a VI.
https://gitlab.com/QSI_Shared_Code/quick-run
Quentin "Q" Alldredge
Chief LabVIEW Architect, Testeract | Owner, Q Software Innovations, LLC (QSI)
Director, GCentral | Admin, LabVIEW Wiki | Creator, The QControl Toolkit
Certified LabVIEW Architect | LabVIEW Champion | NI Alliance Partner
Message 34 of 34
(2,281 Views)
