Quick Drop Enthusiasts
Reply
Highlighted
Quick drop plugin: Add to event structure
This plugin takes any amount of selected controls, and all controls (not indicators!) that are selected will have a "Value changed" event added for them to an event structure. The block diagram terminal will then be moved into the event case matching it.
I use this constantly whenever I am creating a user interface VI.  It's far easier to select 20 controls and press Control-space, Control-E than it is to individually add 20 new event cases to an event structure to handle the assorted buttons and data entry fields that I've just placed.
This was developed and tested under LabVIEW 2015 only, so I don't know if it's backwards or forwards compatible.  Default shortcut is Ctrl-E.
(1,111 Views)
Re: Quick drop plugin: Add to event structure
Very neat and I could see using this.  That being said have you thought about making it into a right-click function too?  I feel like this could be useful since this can provide the context of Create >> Value Change Event but that menu item might not need to show up if indicators are selected.  And besides that I already have a CTRL+E QD (Explorer) that I use pretty often.  We can all admit the QD shortcuts are getting cluttered and while this is useful, the majority of the VIs I write I wouldn't use this on, so maybe a sub menu item would be more appropriate.  Still kudo'd and love it.
Unofficial Forum Rules and Guidelines - Hooovahh - LabVIEW Overlord
Interesting in learning all you can about automotive CAN bus communication? Checkout my 12 part CAN Blog series.
(1,101 Views)
I didn't think of making it into a right-click function, mostly because (like you) the majority of VIs I create don't have interactive front panels with event structures, and I prefer to keep my menus slim since I see them all the time.  Quick-drop, on the other hand, while I may use it a fair amount, it doesn't show you the plugin names unless you click a couple of things.
If someone feels like it they are certainly more than welcome to create a version that puts itself in the right-click menu by copy-pasting the relevant code from this one.
As for the shortcut, I suppose it could also be Control-V (for Value change) or some other key... how many letters do you have left?  I've just added this one plus two others to the basic set that came with LV, so I had plenty...
(1,090 Views)
Darin already has something along these lines.  Have not looked to see if it works on multiple controls though: Create Event
(1,062 Views)
Apparently I'm really forgetful...
Lets see, I use M, A, F, I, T, E, O, Q, R, P, B, D, W.  To be fair a couple of those I don't use often and should probably remove them.  And also there are times that I would want to paste text into my QD window using the V for paste.  I had that complaint for the Viewpoint SVN toolkit which added a QD function using the V which I learned as soon as I tried to paste in there.
(1,058 Views)
Reply
