FYI to everybody, if you've ever needed to implement functionality in your LabVIEW application that mimics Quick Drop (i.e. typing in a window to filter a list and select an item), check out the Quick Drop UI document I posted on ni.com. It's a simple subVI you can drop in your code, pass it an array of strings, and it pops up a window that behaves just like Quick Drop to give your end user an easy string selection and filtering UI.
