Quick Drop Enthusiasts
Quick Drop Keyboard Shortcut - Nattify VI
Thank you Darren!
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
Message 21 of 24
(536 Views)
Hi Darren
Do you know whether Bug 2089884 was fixed?
The QuickDrop Read QDKS INI Info.vi comming with LabVIEW 2023 Q3 patch7 is password protected.
Message 22 of 24
(163 Views)
@code-lux wrote:
Hi Darren
The Bug is still not fixed. You can use the patched version of the VI that I attached up-thread to manually fix it on your system.
Message 23 of 24
(156 Views)
Hi everyone, sometimes I'm refactoring vis that contains a lot of wires, some overlaping functions, etc. so this is a Nattify quick drop plugin (the original one) with 2 additional tasks
  • Cleanup wires - It traverses the Block diagram to find all the wires on it, then executes the CleanUpWire Method
  • Separate compiled code from source file
Code saved in LabVIEW 2018
Message 24 of 24
(37 Views)
