Quick Drop Enthusiasts
Quick Drop Keyboard Shortcut - Disconnect from Typedef
Disconnects controls or constants from their source type definition. If [Shift] is also pressed, disconnects all controls/constants within the selection from their source type definitions recursively.
Follow these instructions to install and use this shortcut:
  1. Save the attached VI in your <LabVIEW>\resource\dialog\QuickDrop\plugins folder.  No LabVIEW restart is required.
  2. Select one or more controls/indicators/constants in your VI.
  3. Press Ctrl-Space.
  4. Press Ctrl-Y. The controls/indicators/constants will be disconnected from their source type definitions.
  5. If you had pressed Ctrl-Shift-Y instead, all controls/indicators/constants within the selection would be disconnected from their source type definitions recursively.
This shortcut works in LabVIEW 2013 and later.
Message 1 of 1
(8,324 Views)
